×I'm just testing the business class version of trello and was wondering if the power-ups I'm installing now and all the settings I've been changing will remain or if everything will be deactivated when the trial period is ending ? What happens with the teams that I've added ?
After the trial ends, the team you have created will remain the same only if you have more than 10 boards in a team then except for the first 10 boards all boards will be archived! You can unarchive the boards too after you reduce the no. of boards on the free plan!
Except for the 1st power-up that you have installed, all other power-ups will be disabled!
Thanks for the quick reply.
What exactly do you mean by "You can unarchive the boards too after you reduce the no. of boards on the free plan"
I've to decide which boards I want to keep and the other ones will be gone/archived for ever ? Or will they go back being "private" boards ?
If you have
board 1
board 2
board 3
board 9
board 10
board 11
board 12
in a team, then after the trial ends the 1st 10 board will be visible in the team
board 11 & 12 will be archived!
If you upgrade your plan you can unarchive these 2 boards again!
or you can move 2 boards to another team then you can also unarchive board 11 & 12.
You can't choose the board which will be archived it will do automatically just like I told you above.
None of your boards will be GONE FOREVER! you can recover/unarchive them easily by following the above method I shared.
Like email in gmail, when your boards are archived, they do not disappear forever. But you have to go to the closed boards and reopen them to use them again. You can only reopen them if you have less than 10 boards (or if you upgrade to Business Class).
@Soumyadeep Mandal - SaM @Michael Pryor
Thanks for the explanation. I will open a new team and split up the boards for the moment.
