Multiple boards, lists and cards & multiple members. How do I keep track of the important happenings? Due dates are not always used since sometimes our cards are just for brainstorming.
Thank you, WAO
Hi @Walter Osterman !
Are you looking to keep track of your own personal tasks, or are you needing to oversee a team as well (or both)?
Team tables might help, also Unito can enable you to build master boards that consolidate cards from multiple boards. For example, you can create a "Master Walter to do" and only sync the cards assigned to you/the important ones to your master board and just work out of the one board.
No problem! Let me know if you need a hand with any of that :)
Hannah,
Would you know how to add a due date to a project in Jira Work Mgt?
Thank you,
Walter
