When I change the due date from a card in Trello, the change isn't visible in my calendar.
Do you have more information on this? Is this the first time you're setting up you calendar with a trello feed? Are you on a Windows or a Mac?
It is indeed the first time I use the calendar and I are on Windows. My problem is that the calendar doesn’t seem to synchronise in my Outlook calendar when I change a card in Trello from ‘To do’ to ‘Done’.
If you've set up the feed correctly once and your Outlook calendar is showing cards with due dates, then It sounds like the problem might be that Outlook doesn't update from the calendar feed in real-time.
Does it just take a long time for the status to update from ‘To do’ to ‘Done’? Or does it just not update any more?
Also, when you say it moves to 'Done' does that mean you move it to a list named "Done" or does that mean you check the due date box?
