I am looking for a way through which I can put the restriction of assigning not more than 2 cards per member?
Also is it possible to restrict only one member per card? Like we do in Jira?
@Nandish Ajani you can do it through the API, here's a Trellinator function that will remove a member added to a card if more than one member exists after it has been added and posts a comment notifying the adding member that only one member is allowed:
https://gist.github.com/iaindooley/6ebdd1975319c4f5a165a0eca563a240
Here's a function that will remove a member from a card if they are a member of 2 or more cards already when added:
https://gist.github.com/iaindooley/398296f74e001383b2c66d8c3a2a9256
You can read more about Trellinator here:
Thank you.
As I am a Python Developer are you aware of any such resources in Python? Also, can we achieve this using the core API that is provided by trello?
https://developers.trello.com/reference/
@Nandish Ajani I've only written Trellinator as a Google Apps Script framework, you're welcome to port it to Python if you want ;)
And yes it just uses the Trello API under the hood, so you can write the code to do this using Python hosted on a web server.
