I use both Trello and Evernote and I rely deeply on the power-up to connect the two services. Recently, I've noticed that when I copy and paste an Evernote internal link into trello, it no longer auto-populates the note name from Evernote. Instead, it shows the "raw" URL only.
My work-around is to copy/paste the link, and then copy/paste the note name. I would prefer if the note name would just auto-populate like it used to.
In an attempt to solve this, I disabled the Evernote power up in Trello and then tried to re-connect it. When I did that, the Evernote authorization window said "OAuth request token is not valid."
Are there any current problems with the Evernote power-up?
Thanks!
Hey, Trello support responded to me with:
"I'm sorry to hear about the trouble. Our API key used by the Evernote Power-Up was disabled yesterday, which is why the authentication is failing. Our team is currently communicating with Evernote to get this resolved.
I'm sorry that I can't provide an immediate solution to this right now, rest assured the team is working on getting this fixed as soon as possible."
I guess we should be patient
I'm having the same issue!
