Is there a way to reset a checklist everyday automatically?
jlehman256 April 3, 2022
One of the tasks on my board counts the number of cookies I've eaten that day. When the next day comes (say midnight) I'd like for it to uncheck all the checks I've made so I don't have to manually tap backwards from 14 lol. Small request just wondering if it can do it. Thanks
milynnus
April 4, 2022
@jlehman256
This action
reset all the checklists on the card
allows you to do that. However, it is not available under calendar. So you have to use a calendar command to trigger a rule command with the above as part of required action.
Casey Royer
February 9, 2024
Can you expand on that?
I'd like to have my daily to-do list cards automatically move to my "DONE!" list at the end of the day, then every Monday have the cards moved back to my daily list and have all the checklists on the cards reset.
Thank you!
