Is there an easy automated way to advance due date to the same day of the same week for next month?
Kelly Sattler September 8, 2023
I track my recurring meetings in a Trello board and I'd like to see them on the calendar. To see them on the calendar, I set a due date. I'd like to automate the advancement of the due date.
What I found in automation advances the due date to the next month and keeps the date (ex. Sept. 5th becomes Oct. 5th) but what I want to do is keep it on the same day of the week and during the same week (ex. 1st Monday of Sept moves to the 1st Mon of Oct.)
I can create 20 buttons that do that (4 weeks x 5 days/wk) and put the right button on each card, but that still requires me, I think, to enter every card and click on a button.
The columns are the days of the week and I have labels on each card in the column. I didn't see where I could use these in the automation section.
I am on the free version, so that might also prevent me from doing what I'm trying to do.
Any ideas or automations that you can suggest to help?
Daydreamer Mike
Hi @Kelly Sattler
You can use these automation actions to shift the dates to the same day next month...
Kelly Sattler September 11, 2023
Thanks! I saw that and tried it but it shifts it to the same date, not the same day. So, if I had something due today, Sept 11th, which is the 2nd Monday of September and I used that automation, the due date would move to Oct. 11th, which is the second Wednesday. I want to keep it on the 2nd Monday.
Daydreamer Mike
I just tested it and you're correct, the month and year use the day of the month (as in 1-31) and not the actual day. The wording is a little misleading I agree...
There are some convoluted ways of doing this with automation, which would be a bit easier if you had a paid subscription and custom fields.
Have you tried the Trello Card Repeater?
Like Kelly Sattler likes this
I did. It resulted in a lot of extra cards. Perhaps I could try it again with a rule to delete cards that were due last month or are past due.
