Jira Power up Authentication
meutation
September 10, 2025
Hello, I have seen identical issues from 2022 around Jira Power Up Authentication loops.  I am experiencing that same issue right now (Sep. 10, 2025).  I get through authentication and authorization the first time, then loops again through the same process, then hangs on Verifying.  It has been working for years before the recent Jira navigation change.
I have been through ALL the troubleshooting steps with no success, and I mean all of them so I will not list them.  Any thoughts here?
Nivedhya Vikram
September 10, 2025
Hi @meutation ,
Welcome to the community!
It seems you are running into an issue that is being tracked in the following bug report here: TRELLO-1496.
I have added this post to this bug as an internal comment for our engineering team to see and reference if needed as well as align priority. I would also encourage you to visit that bug, log in with your Atlassian account, and click Start watching this issue on the right panel. That way, when the ticket is updated by our development team, you'll be notified via email.
There are a number of factors that determine how Atlassian prioritizes bug fixes. You can learn more about this by reading the Atlassian Cloud Bug Fix Policy
meutation
September 11, 2025
thank you @Nivedhya Vikram I appreciate the rapid response and knowledge it is a bug being tracked.  I will keep an eye on the bug ticket.
