Mirror card automation not mirroring entire card?
Ashley
January 17, 2025
I'm super excited that card mirroring is available now! I am running into a few issues, however:
- when I right click a card and tell it to mirror to another board, everything works appropriately
- however, when I set a rule to automatically mirror any card added to a specific list, I am getting, at most, the card title in the mirrored card. See screenshots:
This is all I get on the mirrored card:
Any suggestions would be much appreciated!
Alisson Sartor
January 20, 2025
Hello, Ashley
Welcome to the community
Are you using this option below?
To mirror a card with automation:
  1. When adding actions to an automation, select the Add/Remove category
  2. Find the create a card action
  3. Select mirror from the card type dropdown
https://support.atlassian.com/trello/docs/mirroring-cards/
Kind Regards
Alisson
Trello Team
Lutz Wilde January 23, 2025
Hello, i am dealing with exact that problem too. Mirroring via button on Card works exaxtly as axpected (a perfect twin of the origignal card, which reproduces every changy on the original card on the fly).
But when i put an automation behind the board like explained above, i create cards with nothing than the Trello-Link in the title. I am very exited to get a hint! Greetings from Berlin, Lutz
