Multiple users - possible to edit same note
Ola Schönbeck September 3, 2020
Hi
I have searched everywhere - probably I am blind - feels like a basic feature?
In Trello we use a common board with a group of 3 users.
If i make a new List with a new "note" and then writes a some information in this note.
Is there a possibility/setting for all 3 users to edit this note?
Now the other 2 users can comment not add info in "my note"
Example:
User 1 note:
[Client instruction - Adjust volume to 20]
User 2 got new info from the client and wants to edit my note to:
[Client instruction - Adjust volume to 43]
I haven't find a way of doing this - is it possible?
Best regards
¤Ola Schönbeck
Iain Dooley
@Ola Schönbeck what do you mean by "note"? All members of a board can edit all aspects of a card, but if you're using a powerup then there might be other permissions involved.
Ola Schönbeck September 7, 2020
Thx for your super fast reply!
This is a very old board. Maybe 4-5 years old.
I tested  to create a new board with new members - everybody can change everything. Just as I want it.
Somehow it is not possible to change what somebody else has written in this old board.
I have searched and compared to the new board and can not find a way of unlock editing for all users - it looks like editing is enabled... See attached image.
I am Ola and my college is Anton.He can not edit ("Redigera" i Swedish) my notes and I can not edit his notes.  We can only Answer ("Svara" in Swedish) - not edit or delete...
I hope this clarifies my problem a little bit more?
Iain Dooley
@Ola Schönbeck okay yep you can't edit or delete comments added by another user who was the same access level as you at the time they made the comment. Anton was obviously an admin of the board at the time that comment was made. If you wanted to, you could simply copy the board, close the original and then you'd be able to delete the comment on the copy.
Hope you all can help :) ?
