Power-ups do not show on cards
rajp December 9, 2021
I previously enabled and used the salesforce power-up on my card but now it does not show.
Has something changed since the last set of UI changes?
Alex W
December 12, 2021
Hey @rajp - can you make sure you have the Salesforce power-up enabled, and check if you can see a Salesforce button in the header or in the Board Menu under Power-Ups?
A screenshot of what you're seeing may be helpful to troubleshoot.
rajp December 13, 2021
Thanks for the reply, Alex.
Attached are some screenshots.  This had worked flawlessly before.
rajp
Screen Shot 2021-12-13 at 6.07.04 PM.pngScreen Shot 2021-12-13 at 6.07.33 PM.png
rajp January 1, 2022
Hi Alex or anyone,
Any clues from the screenshots?  Does the Salesforce power-up now need a Trello subscription level?
rajp
Alex W
January 3, 2022
Hi @rajp you don't need a Trello subscription to use Salesforce but you may require a Salesforce subscription.
Have you authenticated the Power-Up in Trello?
rajp January 3, 2022
Hey Alex,
Yes, authenicated  to Salesforce before.  It just stopped working.  I've contacted "Support" to check if this is a bug.   I cannot get to edit previous automations either so perhaps it is a general issue with my account.
rajp
