Hey @rajp - can you make sure you have the Salesforce power-up enabled, and check if you can see a Salesforce button in the header or in the Board Menu under Power-Ups?
A screenshot of what you're seeing may be helpful to troubleshoot.
Hey Alex,
Yes, authenicated to Salesforce before. It just stopped working. I've contacted "Support" to check if this is a bug. I cannot get to edit previous automations either so perhaps it is a general issue with my account.
rajp
