Snooze Power-up stopped working
Nathan Stuller December 11, 2024
As of the last day or two, when I snooze a card it does not set the snooze return time, it only archives the card. There is no indication of an error or anything. It just doesn't work anymore.
Carolina Lopez
December 12, 2024
Hi Nathan, welcome to the Atlassian Community!
Let's try starting with a clean slate to see if that helps get the Snooze Power-Up working again. Would you mind trying the following steps please?
  1. Go to the board where this Power-Up is enabled.
  2. Open the Board Menu and select Power-Ups.
  3. Look for the Card Snooze Power-Up.
  4. Click Settings, select Remove personal settings, and Disable the Power-Up.
  5. Go to https://trello.com/my/account
  6. Under the Applications section, select Revoke under any entries for Card Snooze Power-Up (if any are found).
After that, go ahead and reenable the Power-Up. Let me know if this helps!
Choo Yan Bing
August 3, 2025
Hi Carolina,
 The snooze power up has disappeared for me as well. Tried these steps and it doesn't work. Will appreciate your help.
Sakshi Verma
August 4, 2025
Hi @Choo Yan Bing  ,
Have you enabled the power-up on the board? If not, please enable it first.
https://trello.com/power-ups/58dd18bdccfca7af8311792e/card-snooze
Let me know if it's enabled and you're still facing issues. You can also send me the link to the board from which it disappeared.
With Trello's new update, we have reposted certain features, so if you open a card and click on the section below, you will see the power-ups.
Thank you.
Jacek Skrobisz
August 21, 2025
I also have an issue with the snooze function. I don't see the snooze option (I'm attaching screenshots).Snooze enabled.jpgNo snooze option.jpg
Jacek Skrobisz
August 21, 2025
FREE
