×I can't seem to add the Trello for Gmail power up. I go through all of the configuration steps and then it goes back to the "install" screen without actually installing. Help, please.
@Rachel Maxam welcome the community! Is it this one that just says "gmail"?
If it's that second one, i think you need to configure it from within your Gmail (not Trello). Have you tried setting it up there?
Ah-ha! I feel dumb. I found that you access Trello in Gmail in the right-hand tool bar (that I normally hide) which has an additional permission on the Gmail side (in addition to the permissions when you do the "install" from the Trello side). Thanks!
I feel dumb, too, but thanks!
