Trello for iOS Moving Card Problem
Michael October 5, 2020
For some reason, now when you move a card in the iOS application, Trello now goes to where you moved the card and opens the card, forcing you to close the card and to navigate back to where you are working.  This is maddening.  What is going on?  How do you stop this?  Support does not respond to questions.
Iain Dooley
@Michael I find this workflow to be ideal, I always hated the fact that I was left in the "old" location when moving a card, because more often than not my goal was to move the card and then do something with it, like add members to the card that were not present on the source board.
If you have some board moves that you do frequently, one option would be to set up Butler automations that move the card to the target board when a particular label is added.
Michael October 7, 2020
We work differently, that is all, or I learned to work with the system in place.  Now they have changed it, and I prefer the old way, or at least the option to decide what actions happen after you move a card.
