Unable to load Power-Up
Vincent Ghilione July 21, 2017
I'm creating a very simple Power-Up which should add a button to the board.
I followed the Power-Up tutorial on Trello and created the necessary files over https and added the Power-Up in the admin section.
When I go to any board and try to activate the Power-Up, I can see it in the list, but with an error message "Unable to load Power-Up"
My question is : "is there any way to debug this ?"
Otherwise could anyone have a look to my files and tell me if something looks wrong ?
Thanks in advance for your help
Vincent
Oscar Triscon
July 21, 2017
Looks like your server doesn't set the Access-Control-Allow-Origin header. See https://developer.mozilla.org/en-US/docs/Web/HTTP/Access_control_CORS
You need to add the header to allow trello.com to load your powerup from an scripting request.
Vincent Ghilione July 22, 2017
Thanks Oscar.
I added the header but this still does not work.
I've imported the Trello Power-up template code on my server and it still does not work, which shows that the server is the issue.
Specially seeing that if I import the same manijest.json file from github it works fine.
I've checked both servers HTTP headers but I don't manage to find where this could come from.
Do you have any idea ?
Status: HTTP/1.1 200 OK
Date: Sat, 22 Jul 2017 09:46:51 GMT
Server: Apache
Last-Modified: Sat, 22 Jul 2017 09:38:29 GMT
ETag: "c0cf1a33-298-554e4be8f8c63"
Accept-Ranges: bytes
Vary: Accept-Encoding
Content-Encoding: gzip
Access-Control-Allow-Origin: *
Content-Length: 365
Connection: close
Content-Type: application/json; charset=utf-8
Strict-Transport-Security: max-age=16000000; includeSubDomains; preload
Oscar Triscon
July 22, 2017
Try adding these three header lines:
Access-Control-Allow-Methods: GET, HEAD
Access-Control-Max-Age: 3000
Thanks, it worked pefectly !
Thanks again for your help
Husnain Manj
November 22, 2017
i face the same problem.
Where to add this script?
Vincent Ghilione November 27, 2017
I created an .htaccess file as follow in the powerup folder
<IfModule mod_headers.c>
Header set Access-Control-Allow-Origin "*"
Header set Access-Control-Allow-Methods "GET, HEAD"
Header set Access-Control-Max-Age "3000"
</IfModule>
