I use the card repeat power up. I tried to change a date on the repeat, but when I did so and clicked save, the save went gray, a rollover of the save button shows a circle with slash through it, and the only option I have is to click "x" in the top right and cancel the change. I tried deleting the card and adding a new one, and the same behavior prevents me from setting the repeat date to begin with. I tried restarting the app, and got the same behavior.
Hi Glenn,
I am not sure if anything has changed with card repeater recently but it is possible to create a recurring task engine using custom fields and automation. It can be exactly like card repeater but you can also make it do so much more...
If this gets 10 votes or more, I'll create an article on how to do it 😀
This is happening to me, too. I've tried it on the app and on the browser. Card repeat settings do not get saved. (I'm on an iMac running on Big Sur.)
@Glenn Levine @Cynthia Gilbertson
Just out of curiosity, is this happening to you on a a Mac? What browser are you using
I used the Card Repeater powerup for a client last week and it was working fine. I am using Windows 11 and Chrome as the browser...
Yes, I'm on an iMac running Big Sur (11.7.6) and Chrome. Sounds like it could be a mac-related problem.
