Unfortunately, your answer if a bit vague. If you want assistance you will have to describe exactly how the power is not working. What are you trying to do? What are you expecting?
i have 20 plus cards with due dates, how do i get all the due dates to show up in my google calender. if i go to each card, i can see the due date on the calender but i cannot see the whole picture of all the cards on one calender
Have you completed the steps at at https://help.trello.com/article/829-using-trello-with-google-calendar? This process will create a new calendar for the board with all the cards and dates.
No, you make the connection for the entire board. All the cards on the board will show in the new sub calendar on your Google account.
i did that and then added a card and it didnt show up on the calender
The initial sync can take up to 24 hours to sync. Please give it some time and check back tomorrow.
