is possible to insert GPS coordinate instead address?
regards
Sebastiano
@sebastiano soprano Worked a bit to study Map because I wanted to modify the loc via a program. While the pluginData can be access via API, you cannot change it. The user interface is the only way to enter a location via a search and update its name.
thanks @milynnus , but the search is possible only by address?
in many case i've the address without civic number but i've the gps coordinate.
Sebastiano
@sebastiano soprano More like text because you can get places that matches. Have not tried local postal codes.
@milynnus gps coordinate?
@sebastiano soprano don’t have it installed but you should just type in and try.
