×Hello,
I want to be able to calculate the severity of a ticket based on multiple variables:
- time spent in solving the ticket
- number of affected customers (intervals 0-10 customer, 10-50, more than 50)
- severity of problem (1- low, 2- medium, 3 high)
At this point i don't know where to start.
I want to be able to do this thing both on Jira and Trello.
Thank you!
I can help you from the Trello side of things.
You can then have a numeric "Severity" custom field that is calculated based on the above conditions and an automation that when the custom fields above are complete, set Severity to "{{%Open Time}} * ({{%Affected Customers}} * {{%Severity}}"
You can tailor the calculation to your needs. You can find out more here:
https://support.atlassian.com/trello/docs/arithmetic-and-formatting-in-date-variables/
