When I use the Slack Power-Up to post a Trello card to a channel in Slack, the resulting message includes a broken link instead of a preview image (when a cover image has been selected for the card). Here's an example of a card in Trello:
And here's how it appears in Slack. Note the broken image link on the right:
This integration last worked properly with an image preview in Slack on 29 November, if that helps narrow down when a code change might have caused it.
Thank you for taking a look!
Hi @Todd Lewis
Thank you for reporting this! We have identified and fixed the root cause of the issue. It should work now. Sorry for the interruption. Could you please give it another try? Let me know if it works for you now.
