As of the last day or two, when I snooze a card it does not set the snooze return time, it only archives the card. There is no indication of an error or anything. It just doesn't work anymore.
Hi Nathan, welcome to the Atlassian Community!
Let's try starting with a clean slate to see if that helps get the Snooze Power-Up working again. Would you mind trying the following steps please?
After that, go ahead and reenable the Power-Up. Let me know if this helps!
Hi Carolina,
The snooze power up has disappeared for me as well. Tried these steps and it doesn't work. Will appreciate your help.
Hi @Choo Yan Bing ,
Have you enabled the power-up on the board? If not, please enable it first.
https://trello.com/power-ups/58dd18bdccfca7af8311792e/card-snooze
Let me know if it's enabled and you're still facing issues. You can also send me the link to the board from which it disappeared.
With Trello's new update, we have reposted certain features, so if you open a card and click on the section below, you will see the power-ups.
Thank you.
