×I would like to track how long a card is in each column in trello. Essentially as the card reaches the final stage in the project, I want a breakdown on how long that card was in each column ( broken down ) I.E how long it was in the scripting column, then the recording column, the QA colum and so on..
Hi Cara,
You could look at the Time in List power-up which does just this https://trello.com/power-ups/5b4765f383dd7c75d8e57be4/time-in-list
Or for some more complete reporting check out Blue Cat Reports https://trello.com/power-ups/5d9c90aa18965066fcd44730/reports-by-blue-cat
You can use the Time to Complete chart in Blue Cat to track time across individual or multiple lists.
Robin
