We use Card repeater for several months. In the last time (maybe since about Business Class -> Premium change ?) there are problems with this power up. The cards are correctly repeated as they are set, but we do not see anymore on the card the time when it will be next repeated. For most of the cards when we open them and check on the repeater power-up we also do not see the repeating setting, but for some we see. When we check on the board the Repeater, then it shows all of the cards when they will be next repeated, and there are all there.
Is there a better, faster, more efficient way to correct this problem then set a new repeater setting for all of the cards? (But it will not cure the problem that on the card isn't showed the next time, only when on card opened the repeater power-up)
Thanks for the answers.
Hi Nagy,
Thanks for reaching out!
We did have an issue where the repeat was not shown on the card back, however that issue has since been fixed. Let me know if the issue persists for you!
All the best,
Lara
The Trello Team
If there is no good solution, then ok... It was a try worth :)
(updated all repeat cards...)
