Unable to locate enabled power-ups easily
Oliver Bullock May 25, 2017
I have got quite a few trello boards and currently using the free price plan.
I have enabled a power-up on one of my boards but not sure which one. Is there an easy way to see and disable the power-up without having to go into each boards?
Kaylin Murray June 2, 2017
Hey Oliver,
Not sure if you already went in and did this but I believe with some powerups you can revoke access under your profile in the settings tab. This may turn off the power up on the board without having to go into each one!
Hopefully this helps!
Oliver Bullock June 3, 2017
Hi Kaylin,
Thank you for your response, I will check it out,
Cheers
Oliver
Matthew N
May 26, 2017
Hey Oliver
You'd actually need to go into each board to determine what power ups are enabled. They'll all show on the power up list. But there's not a way to see all power ups enabled across your boards.
Oliver Bullock May 26, 2017
Thanks Matthew for the response. I suspected as much but wanted to check I was not missing something.
