While wont using Geopoint Lat/Lon in Maps power up work ?
Murray Henshall
January 25, 2021
Seems using Latitude,Longitude (-23.8457981,150.2619968) wont work in the Maps power up on a card. ?
Or is the format incorrect ?
Thks from a newb.
2 accepted
Lara
January 28, 2021
Hi Murray,
Thanks for reaching out!
Right now, there isn't a way to enter lat/lon coordinates in the Map Power-Up – I've flagged this as a feature request with the team 👍
If you have dev resources, you could achieve this via the API and ensure you're passing coordinates with your request.
I hope that helps!
All the best,
Lara
The Trello Team
Murray Henshall
January 29, 2021
Vero Rivas
January 28, 2021
