Why can't I edit settings of " Read Me" power up?
Marina Neira
June 7, 2022
I just enabled the "read me" power-up. However, when I go to "edit power-up settings" nothing happens upon click. How can I access the settings, please?
Theodoro Reato
June 16, 2022
Hi Marina,
I tested it, and it worked for me. Could you check this article Troubleshooting browser issues with Trello for detailed instructions on troubleshooting any problems with Trello in the browser? You are probably experiencing a problem in your browser that is preventing you from accessing the readme settings.
Also, it's important to check if you're using a supported browser, can you check that as well? And see if your browser is up-to-date.
Change the browser it's a nice try as well!
