My calendar power-up is not showing up on only one (of many) Trello boards.
Any help would be greatly appreciated! Thank you!
Image #1
Image #2
Image #3
Image #4
Hi, Cindy! Welcome to the Atlassian Community!
First of all, thanks for providing such a thorough and complete set of information when raising your question.
We're sorry to hear that the Calendar Power-Up is not showing up on one of your Trello boards. Although the Calendar Power-Up is still up and running, we've received similar reports from other customers. In all those cases, it seems simply disabling and then re-enabling the Power-Up resolved the issue.
I'd recommend you try doing the same thing and re-enabling the Calendar Power-Up on the affected board. Meanwhile, we have an ongoing internal ticket actively investigating what could have caused this issue.
If the problem persists after re-enabling the Power-Up, please don't hesitate to contact us on https://trello.com/contact.
Once again, thank you for your detailed information, and we appreciate your patience while we work on this issue!
