Yesterday the calendar power up stopped working, on both boards where it's enabled.
When I click the calendar power up button the screen flickers like it's about to change to the calendar view but then goes back to the normal view. It does this on both boards where I use the calendar power up.
I've tried disabling & re-enabling the power up. I've tried reloading Trello. I've tried restarting my laptop but nothing helps.
I spend most of my time in calendar view on those boards so losing it is a real issue!
Hi Kate,
Welcome to the Atlassian Community! 🙂
Hmm, I can't reproduce the issue you're describing as the Calendar Power-Up seems to be working as expected for me in several browsers.
Do you also use Trello in a browser? If so, I'd suggest first following the instructions available in this article: https://support.atlassian.com/trello/docs/troubleshooting-browser-issues-with-trello/
You can also try using a different browser to see if the Power-Up works there.
Hope this helps!
Alina | The Trello Team
Hi Alina
Thanks for your help!
I should have thought of trying a different browser - it worked with Edge. When I disabled all my Chrome extensions that sorted it... even when I switched all the same extensions back on.
Appreciate the help, I'm lost without the calendar on those boards.
cheers
Kate
Yay! Glad to hear it worked, Kate 🙂
Hope you'll keep enjoying using Trello!
