Using the automation rule features, am I able to assign checklist tasks based on custom field value?
For instance I created a rule like this:
when custom field "Card Owner" is set to "team member name", assign the item to member @teammember name.
What I want is that all of the checklist items in a certain checklist (which is already part of the card when the card is created from a template) will get assigned to the team member who is selected as the value for a custom field called "card owner"
Is this possible?
The rule is currently not working for me.
You were so so close 😊
You need to add the "for each checklist item" action from the Cascade list:
