issue scolling on Slack power-up
Martin
October 12, 2023
For some reasons it seems impossible to scroll down in the pop up window when trying to link a trello table to a slack channel. I tried on Chrome and Edge, the issue is on both browsers. I have been able to use it properly until today
Beverley
October 15, 2023
Hi Martin - welcome to the community!
Thanks for taking the time to send us that bug report; I was able to replicate the issue.
I’ve passed on the details of the bug to our development team so they can prioritise working on its fix. While I don't have an ETA on when a fix for the issue will be pushed, we will deploy it as soon as one is available.
In the meantime, you can still set up Slack alerts, but the workaround would be to continuously press the TAB key on your keyboard to move down the page and reach the bottom. Then you can select the other alerts you'd like to enable.
I hope that helps!
