×Since like 2-3 weeks it does not work to add other persons with @username to a card. before it was possible to add someone to a card on the trello board while creating the card. Is this a bug, or was the feature removed on purpose?
Sadly it was removed and unfortunately with very little notification. This thread explains, it was the # for labels and @ for members that was removed.
You can use this article I wrote to partially replicate the functionality, modified to use the @Member instead of #
Hope this helps:
Mike
