problems with Trello-Kalendar
Björn Krüger
September 20, 2020
Hello!
I just joined Trello, now I have some problems with the calendar, but these only occur when using the Android app.
1. Android app: Due dates of checklist entries are not displayed in the calendar.
The due date of a checklist entry is only shown in the calendar if the corresponding card also has a due date.
in the web and windows version all dates are displayed.
2. board wide calendar
I use several boards, in each one I have installed the calendar powerup.
In order to keep a better overview of my appointments, I would like to use a cross-board calendar that shows all appointments from all boards.
Is that possible?
Thanks and best regards
Bjoern
Garrett
September 24, 2020
Hey Bjoern,
Currently both of these behaviors are expected, although I'll be sure to let the team know about your interest in that.
Due dates on checklist items are a very new feature so some specifics such as those on the mobile calendar won't show currently.
For the global calendar view, that's not a feature that's available currently.
For now, you could add each of your boards' iCal feeds to Google Calendar, or another app which subscribes to iCal feeds: https://help.trello.com/article/829-using-trello-with-google-calendar
To make that process a little bit simpler, there's also a calendar connector Power-Up from Cronofy that can help you connect multiple Trello boards to your preferred calendar app: https://trello.com/power-ups/5a1d81359fcdfd9011c0a698
