technical requirements to work with Trello
Ruben Reyes Ruiz
June 28, 2018
what are the technical requirements that I need to work with Trello?
Fernando Bordallo June 28, 2018
Hello Ruben,
Your question is very broad but I'd say there are no technical requirements from the user perspective. The Trello boards are free to create and easy to use. Make tickets, columns and move them around while you add information to them (name, description, tags, comments, ...).
Your minimum requirements should be a device with connection to internet and either a browser or the trello app. Aside from that, can't think of any limitations.
Does this answer your question?
