Hi Nicolas,
Thanks for your reply, I have no concerns using JIRA in this way, I'm just looking for any Business Cases that can justify this approach in terms of cost saving, risk reduction etc. I have the task of justifying the investment required to senior management to implement this change.
Many thanks
Mike
Well, if you use Jira for this you will experience more efficiency in this process, it will certainly saves you a lot of time. The teams and the stakeholders will have a much better visibility than with a spreadsheet. With Jira you can easily discuss the requirements within the tool to get a maximum of feedback, you can quickly find requirments with an access to the full history, you can make and share reports, you can link requirements, group them in just some clicks...
If you need a real-life example you can check the projects of Atlassian :-)
There you see the different issues, how they are ranked, commented, how they evolve,... And you can see how it works when it's open to customers feedback (not mandatory, you can keep the tool visible only for your team).
Thanks Nicolas,
I'm struggling to find anything in Projects of Atassian sepcifically relating to this approach, have you come across anything previously?
Mike
You're welcome. I suggest you read this post so you can understand how Atlassian works and see if it's a good example for you
Thanks, I'm not sure this gives me what im looking for, I understand what JIRA can do and how to do it, I'm looking for a justification/business case of real world examples of where this has been done before.
Alright. You can have a look here . Atlassian lists many customers and offers business cases. You can probably find cases that are similar tou yours. Hope it helps.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
