I'm currently using the JIRA API with JQL to obtain the released fix versions for a given project ID. However, this approach is time-consuming as it returns the entire document, and I need to filter out only the fix version names.
Is there a more efficient method to directly retrieve the list of released fix versions for a project?I'm interested in exploring alternatives that can improve performance and reduce the amount of unnecessary data returned.
Hi @abhishek.y
I think you're almost there with the call you're using. If you modify it a little and add the fields query parameter with the value of fixVersions, you get a list of issues with only the fixVersion field (and some central ones like issue id and key):
https://yourdomain.atlassian.net/rest/api/2/search?jql=project%3D%22ProjectName%22%20AND%20fixVersion%20in%20releasedVersions%28%29&fields=fixVersions
You can find more details in the REST API documentation. Here's also an example query on Atlassian's public issue tracker.
Matthias.
Hi @Matthias Gaiser _K15t_ this reduces the time to almost one third just found this solution this morning, but still thank you for your help.
But is there any other way in which we don't have to use JQL query maybe it'll make the response time lower?
You can use paginated https://docs.atlassian.com/software/jira/docs/api/REST/9.12.7/#api/2/project-getProjectVersionsPaginated or unpaginated https://docs.atlassian.com/software/jira/docs/api/REST/9.12.7/#api/2/project-getProjectVersions REST Api call to get all versions of a project. You can then loop of the returned versions and filter out the release ones.
Hope this helps.
Hi @abhishek.y ,
If you are open to apps you can use Versions Dashboard for Jira , an app released by our company.
You can filter for various criteria, one being Released - Yes.
The tabular format data has sortable columns and can be exported to csv.
Petru
Our company developed CIFJ - Versions Dashboard for Jira, which allows you to search versions across your organisation.
https://marketplace.atlassian.com/apps/1235582/cifj-versions-dashboard?hosting=cloud&tab=overview
You can filter by Project and other criteria, including Released.
You can visualize the result in a table or export to CSV.
To efficiently retrieve released fix versions for a specific project ID in JIRA, use JIRA Query Language (JQL) to filter issues by the project and released versions. You can also access the project’s "Releases" section, which provides a list of all released fix versions directly. Additionally, consider using the JIRA REST API for programmatic access to version data if automation is needed. These methods will help you quickly find the relevant information.
@Hi @abhishek.y
Are you looking to get issues in released versions or just the list of versions?
If you only want the versions, the API /project/{projectIdOrKey}/version accepts a query param status=released.
Henri, Support Engineer @ Easy Agile
are you using below end point or any other end point in conjunction with this call like (relatedIssueCounts)
"https://your-domain.atlassian.net/rest/api/3/project/{projectIdOrKey}/versions"
