Let's automate project creation using Jira Automation!
43 comments
Kristóf Lauber September 25, 2023
Thats clear, but what am I doing wrong, the URL seems ok to me, and everything else as well, I'm attaching the POST callpost.png
Gerben Heinen
There is not enough info here to answer your question, do you have screenshots that show more, e.g. the url and where your smart value is used in the url?
I attached the GET req below, the full url is:
https://XXXXXXX.atlassian.net/rest/api/3/projectvalidate/validProjectKey?key={{issue.summary.split(" ").left(1).toUpperCase().replaceAll("[^a-zA-Z0-9]","").join("").left(10)}}
Gerben Heinen
Use a smart value calculate as a separate action and put the outcome in the url, the smart value in the url is not processed at all.
How would you go by doing it? If you could give me an example that would be great.
Alexander Ziegltrum
@Kristóf Lauber at one point I had similar issues, as far as I recall. Maybe my approach could be an alterniative for you. I solved this problem using Jira Forms and configured the field for the project key as this:
This is a much more convenient solution, at least for our use case.
Hope it helps.
Thank you @Alexander Ziegltrum for the recommendation, it sounds good, could you please share more info/screenshots about it? whats the purpose of the linkedfield?
Alexander Ziegltrum
@Kristóf Lauber First, you would need to design the request for "project creation automation" in Forms.
Second you add any field you need for your automation. The mentionened form field stores the wanted project key from the user and forwards it to the customfield "JiraProjectKey" that needs to be created beforehand.
In the automation you can work with the content of this field in the smartvalue, when you do the web request for validating the key with smartvalue:
2023-09-25 11_43_16-Jira Configuration - Jira und 4 weitere Seiten - Geschäftlich – Microsoft​ Edge.png
And for creating the project:
2023-09-25 11_44_07-Jira Configuration - Jira und 4 weitere Seiten - Geschäftlich – Microsoft​ Edge.png
Like Kristóf Lauber likes this
Gerben Heinen
You can use the create variable field to construct your key and use that in the API, see screenshot below.
I might not work with what you're doing, because you paste the entire smartvalue operation in the URL.
Thank you both for the help, I was able to do it!
Aron Kuch
Absolutely brilliant! Exactly what I needed. Thank you!
Diogo Teles
February 3, 2024
@Piotr Zadrożny _Eyzee_  What a brilliant article. Thank you so much! The use case alone is great, but the clear way you explain the power of automation+Reat API just takes it to a whole new level. Great work!
Matvei Makeev
April 26, 2024
@Piotr Zadrożny _Eyzee_ , thank you so much for such a beautiful solution! You mentioned automatic creation of boards at the end of the article. How would you do that? I haven't found that functionality in API.
@Matvei Makeev You can create filter using this endpoint:
https://developer.atlassian.com/cloud/jira/platform/rest/v2/api-group-filters/#api-rest-api-2-filter-post
and than create board using this filter using endpoint:
https://developer.atlassian.com/cloud/jira/software/rest/api-group-board/#api-rest-agile-1-0-board-post
You can also create a new project with an already associated board by providing:
  • projectTypeKey: software,
  • projectTemplateKey either com.pyxis.greenhopper.jira:gh-kanban-template or com.pyxis.greenhopper.jira:gh-scrum-template
Like # people like this
Aron Kuch
The final piece!
Thank you @Piotr Zadrożny _Eyzee_! I got it working and this will make it so much more adopted by the end-users since the project is complete.
I'm curious that you used API 2 for creating the filter; why not API 3? (https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-filters/#api-rest-api-3-filter-post)
Thays Carvalho August 9, 2024
Thanks for the post.
Here for me the creation of the software project worked, but it didn't create the board.
Automation doesn't create the board, I know there must be some extra steps to do but I can't find help.
Has anyone ever had this "problem"?
Jason Thompson
This seems like a really cool way to use Automation, but I suppose at the moment, this is only available in the Cloud version?
My company uses Data Center...
I have not found the comparable actions in the DC version, do you know if this functionality is comming to Automation for DC (as someone who has to setup lots of Jira Projects & Confluence areas...)
Thanks.
Rishabh Kumar Shukla
May 26, 2025
Hey Everyone,
Does this solution share/add custom field context for the custom field as well?
