Hey there, Atlassian Community! We’ve heard a lot of feedback from you over the years around the idea of automating actions on a group of issues. Here are some of the things we heard you wanted to do:
Send a daily email with a hyperlinked list of issues and their assignees
Send a weekly Slack message with a list of all outstanding issues
Send a Microsoft Teams message when notifying about all open issues in a sprint
Grab all issues in a particular status, and publish it as a list
Well, we want you to know we’ve been listening.
Based on your feedback, we’ve added a new action called Lookup issues. Long story short, it allows you to search for a bunch of issues, save it as a list, and then do stuff with it.
Sound good? Let’s dive in and take a look!
At a basic level, Automation rules in Jira consist of 3 types of components you can configure:
Trigger - the event that will make your rule start
Conditions - requirements that have to be met, for your rule to run
Actions - the things your rule will do, if it gets triggered and meets all the conditions
In this article, we’re focusing on a brand new action called Lookup issues.
Once your rule is triggered, the Lookup issues action will perform a JQL search that you enter. You can edit your JQL as much as you like so it only searches for the issues you want to include.
You can then access the resulting list using the {{lookupIssues}} smart value.
So in short, the Lookup issues action lets you search for issues, save it to a list, and then do stuff with that list. "Stuff" could mean sending an email, Slack, or MS Teams message. It could also mean commenting, transitioning, or updating every issue in the list. Magic!
Let’s look at an example in context.
Let’s say you’re a team lead, and you want to update your team every morning on how much work is remaining. Instead of doing this manually, you could set up an automation rule and let Jira automation handle it for you.
Step 1: Trigger
All rules start with a trigger; let’s set ours to trigger every day using the Scheduled trigger.
Step 2: Use the Lookup issues action
This is where our new friend, the Lookup issues action, comes in handy. We can enter a JQL query to find all the issues that are in the sprint, and not Done. This list of issues will be saved to the {{lookupIssues}} smart value.
Step 3: Have Jira send a slack message containing the list of issues.
Now, we can take that JQL search we just entered, and print the list of issues somewhere using the {{lookupissues}} smart value.
We’ll go with a Slack message for this example.
Actually, there’s a lot you could do. For example, you could use Lookup issues to:
Take all the issues assigned to one person, and reassign them to someone else (handy for when team members go on holiday!).
Look up all the issues that are in a Review status, and add a comment to each one to remind the reviewer to look at them.
Compile release notes by finding all the issues in a release, and publishing the summary for each issue.
Really, listing out every possibility here would make this article super long - but I’m sure you’ve already got some ideas for your team! If you’re keen to hear from other ideas, check out our most recent webinar.
If you’re excited to jump in and start creating your own rules, head to Project settings > Automation to create project rules or Jira settings > System > Automation to create rules for your entire site
Or if you want to learn more:
To help you get started, see Automation for Jira Cloud getting started guide
To learn more about Lookup issues, including what information you can access from the issue issue list, see Lookup issues documentation.
 Kevin Bui
Senior Content Designer - Automation
Atlassian
Sydney, Australia
55 accepted answers
53 comments
