Previously, upon Bamboo build, open issues can be automatically moved to a selected new version.
It does not work anymore. However if I just click "Release" issues are moved as expected.
Hi @Tomasz Kosinski,
This does not sound like an out of the box configuration between the two servers.
In order to help us to understand what is causing this behavior, can you please share with us:
That should be a good start to troubleshoot this.
I use Server edition
I believe that problem started to be visible when I updated:
Jira 8.2.0 -> 8.30
Bamboo 6.9.1 -> 6.9.2
Can you share more details on how this is configured for you?
Are you using and extra plugin or REST API for this?
I do not use any 3rd parties. Its simple JRIA+BITBUCKET+BAMBOO.
Bamboo builds are started form Releases pane in JIRA.
Hi @Tomasz Kosinski
I'm writing to let you know I didn't forget you. I just needed extra time to set up the environment and test this. As soon I come into a conclusion I'll let you know.
I'm just registering here that I got in touch with you through email and as soon we have our meeting and a conclusion we can post our findings here.
we do have the very same problem - what was / is the solution?
