I see I could access the API at:
https://api.bitbucket.org/2.0/repositories/{workspace}/{repo_slug}/pipelines/
However when I access this URL for my repo I get:
{"type": "error", "error": {"message": "Resource not found"}}
I can only suppose this is because it's not authenticated... However I cannot find any docs/examples on how to do this...
This is as far as I could get setting this up...
To answer myself:
Go to bitbucket, go into your account and create an app password.
base64 encode your USERNAME (not your email) with the password:
Using this format:
username:password
Then add a header to the web request with:
Value: Basic encodedstringyougetabove
And the request works.
Any way you can screen cap what that header looks like? (blurring your username & app password, of course!!!)
Thanks!
