trying to do a bitbucket 4.14 on linux upgrade. I'm trying to build a new instance and copy the data over or upgrade a clone, whatever is easier.
the zero downtime diy backup worked (the name is a lie btw, builds where breaking entire time during the backup), but the restore doesn't work, kept complaining about a missing postgres port which is weird, the entire var config is copied over, there's nothing missing.
So i tried to clone the environment instead and just go from there. The problem with this route is bitbucket is sitting behind a reverse proxy with SSL, If i change all the configs with the new server IP's and hostname it breaks beacause suddenly the cert doesn't work, If i change just the IP the proxy just forwards to the live environment.
How do i change the config to go back to the simple tomcat server instead of using the reverse apache server?
Or, how do i get the zero restore script to work?
What exactly was your postgres error? The restore script is a bit tricky. Can you the error you are getting from the restore script?
the error reads:
[database-postgresql.sh:41 -> prepare_restore_db][bitbucket] ERROR: The configuration var 'POSTGRES_PORT' is required, please update './bitbucket.diy-backup.vars.sh'.
and in the vars folder it's already defined:
POSTGRES_PORT=5432
the vars is exactly the same as the backup. only thing i changed was the postgres IP and credentials so it can restore to the new db server.
went down the reverse proxy rabbit hole. changed all my configs and added a dns entry for my new environment, but i'm getting the following errors now:
[Tue Apr 09 11:12:29.297195 2019] [proxy:error] [pid 18610] (111)Connection refused: AH00957: HTTP: attempt to connect to 10.50.1.92:7990 (bitbucket2) failed
[Tue Apr 09 11:12:29.297364 2019] [proxy:error] [pid 18610] AH00959: ap_proxy_connect_backend disabling worker for (bitbucket2) for 60s
[Tue Apr 09 11:12:29.297469 2019] [proxy_http:error] [pid 18610] [client 10.50.2.31:1409] AH01114: HTTP: failed to make connection to backend: bitbucket2, referer: https://10.50.1.92/
Not sure whats going on here
