It seems that when Compass components are enabled in Jira, existing work items retain their Jira component (had hoped they might automatically convert to a Compass component of the same name).
Given this, we've explored bulk converting work items' Components field content (painfully, one component at a time), however the available options don't actually seem to support this:
Has anyone else come up with a solution for this? The best we've come up with so far is to search for items that only have a particularly component (not that easy) and then use #2 - i.e. not touch items with multiple components.
@Keith Furnell to my knowledge there is no a nice UI achieve this, but there is a script: https://github.com/atlassian-labs/compass-examples/tree/main/snippets/scripts/jira-components-to-compass-components
Useful to know (and surprisingly that it is not mentioned in https://support.atlassian.com/jira-software-cloud/docs/switch-between-jira-and-compass-components/)!
When it says "Use this script to migrate your existing project components along with issues the components are used on to Compass", what does the bold part mean (given that a pre-requisite is that the project has been switched to Compass? Just wanting to understand if this script does more than update the components references on issues...
OK looking at the script I see that it will create new Compass components where there is none matching a Jira component name. That's not the behaviour we're after (we just want to leave such legacy Jira component references alone), but it should be easy enough to adapt the script.
