I would like to know if its possible to configure alerts through integration between Opsgenie and Compass to notify stakeholders, team owners, and etc. if a component were to experience an issue. I'd also like to know if we can directly configure alerts with scores cards in Compass to notify whomever appropriate via email.
Hey there, Josh here from the Compass product team. Our Opsgenie integration is in the works and this is exactly the type of feedback we need, thanks so much!
A few questions if you don't mind:
Are you also interested in getting metrics around incidents and alerts from Opsgenie for use within Compass, say with scorecards? Like having "MTTR" or "number of Incidents" as scorecard criteria.
Do you have any interest in syncing components or teams into Opsgenie from Compass? Or maybe the other way around?
What if you could trigger an incident from within Compass on a given component and alert dependencies that have been defined for the component? Are there other actions around incidents or alerts that you could see yourself wanting to drive or perform from within Compass that would make your life easier?
Thanks again for the feedback, we really appreciate you taking the time. I'd love to hear back on the above and definitely open to hearing any other suggestions!
Related to this, is the idea the the Insight Database is populated with "Services" that can be shared between compass, Opsgenie and Insight. A current frustration with Opsgenie that services are only at the Incident level, and not the Alert level. This would help with the metrics and scorecard items that you were referencing above. @
Hey @Ken Young I would love to add a bit more colour to what we are thinking here. This is still subject to change, but this is where we are:
We would love to grab time with you to talk through this and help inform our roadmap if you have the time. Otherwise, could you write out here a bit more on what you are looking for.
Questions I have for you:
1. How would you like Insight DB, OG, and Compass to work together? Are you using one as the system of record but using maybe Compass as the unified interface to interact with it? What information do you need sycned across all of them?
2. For Opsgenie alerts, would you want to tie all alerts to at least 1 Compass component? Or many? How would you use that with metrics & scorecards back in Compass? How would this interact with our Team Dashboard concept and on-call schedules, rotations, and escalation policies that typically are formed around alerting logic.
Looking forward to hearing from you! Cheers
