We are looking to setup Compass for our Application Governance program, simultaneously we are setting up our CMDB with all infrastructure and 3rd party systems in insight and OpsGenie.
Will there be a relationship between Insight Services, OpsGenie Services and Compass, allowing us to complete a dependency chain from JSM to Compass?
Hey @Oliver Wemyss and @Will Le, thanks for bringing this up!
I would love to dive into the details of the Application Governance program you want to set up in Compass in order to better understand how our current priorities align and whether we can change those to better support your use case.
If you can spare 30 mins grab anytime here: https://calendly.com/tpechacek/compass-alpha
To your question: Yes, there will be a relationship with JSM Services, Opsgenie Services, and Compass Services. We are working with those teams to continue to evolve our offerings around a service object and make that as seamless as possible so you have that dependency chain.
However, Compass is currently still hyper-focused on the developer experience within software organizations that has a "You Build it, You Run it" DevOps mentality. (i.e. a single software team is responsible for building and operating different software components - mainly microservices or common libraries).
Many of our Alpha customers are not currently using Insight or any form of a CMDB, but almost all of them are using some combination of Jira Software, Bitbucket or GitHub, a CI/CD tool, and some observability tools like New Relic, Datadog, Splunk, or Prometheus.
So, the question becomes when and how do we wire up JSM (inc. Insights) and Osgenie. Let me dive into our current thinking here.
In the meantime, you can import components in bulk through the GraphQL API or a CSV importer tool we built. This is a one-time import though so the information is likely to drift over time.
If you do need to unblock yourself, you could invest in a Forge App (or your own small microservice) that takes the data you have in Insight and then updates the information in Compass. The APIs are all publicly available to do this. Let me know if you would like some help mapping that out. Otherwise, if you can wait a few months we will likely get to this by then.
Is there anything else you would expect / like to see that is not captured above?
In support of your "You Build it, You Run it" DevOps mission, the OpsGenie integration is mission-critical as that mentality also implies "You Fix it when it breaks".
@Taylor do you know when 3 above will be released. We currently use JSM and the services / affected services and are looking to start setting up our service catalog but without the Compass/JSM integration we are blocked.
An App for SFX/Splunk will be awesome
What was behind the decision to choose PagerDuty ahead of Opsgenie?
Thanks.
Is there a roadmap on some of these integration ?
Ideally, there is future dev work to use Insight as the source for services and integration across all their platforms for relationship dependency and ticket linkage
