Issue with entries not fully displayed
Oussama Khouri
Hi everyone,
I've encountered an issue in Confluence where the entries for tags in our databases are not fully displayed even though there is enough space on the screen. Has anyone else encountered this issue? If so, do you have any solutions or workarounds?
Thanks in advance for your help!
Rebecca Dai
September 24, 2024
Hi @Oussama Khouri and @Lana Kelly
Thank you for reporting! The team has addressed the issue and it's waiting to be deployed to production. Be expecting the tag field text to only truncate with respect to the width of the field within the next hour or so!
Rebecca
Oussama Khouri
Hi @Rebecca Dai
the problem was partially fixed, thank you and the team very much.
Can the solution be also applied to the page status field?
Here an example what I mean:
Like # people like this
Robert Hean
@Oussama Khouri - based on your screenshot I'm betting there's a hard coded limit to the display length (e.g. it's cutting off at the same length for the longer ones).
May be worth adding a feature or bug request to change the length to be elastic and fit the window (v.s. an artificial cap)
Lana Kelly
We have the same problem.  For the moment, we've split that into separate smaller tags.  So, in your example, it would be "Control implemented" as a tag and "Implement..." as another.
Anne Saunders
September 4, 2024
We tend toward very short tag names, too - maybe that's why I haven't seen it.
Anne Saunders
September 4, 2024
I haven't encountered it in Confluence Databases yet, but Jira has a similar issue in the Filters view.
