Hey, I just checked all dark mode Chrome extensions and found out that the most compatible that seems to have no artifacts in my configuration is the Dark Reader.
I though I'd share with the community.
Here is the extension: https://chrome.google.com/webstore/detail/dark-reader/eimadpbcbfnmbkopoojfekhnkhdbieeh?hl=en
I tested 5 different extensions in Chrome with the cloud instances of:
Jira
Confluence
Portfolio
I did it while working so I did all regular things, commit knowledge to Confluence, create and manage things in Jira, with releases, dialog boxes, etc, and also some basic work in Portfolio.
Let me know if you have any new findings, or you have anything better to recommend.
Cheers!
I found something a little more compatible and doesn't make Confluence look weird.
Open a new tab and type: Chrome://flags
Then search dark mode, then enable. Restart browser
Everything is now in dark mode. Even Google Calendar!
it works, thanks.
Also works in Edge
edge://flags/
