×Hi There,
So I recently discovered Jira Issue/Filter macro and wanted to create a dynamic data table. I used a JQL in the search and choose the columns I needed to display. Once published we got all the 20 issues/entries required in a table like form. Our requirement now is in the output table, we need a column called "Comments" and we need to be able to update them manually against each of the entry. Is this possible? I did see a few examples here on the forum but it was for auto-populating from another table against a type of status. Here we every issue will need manually added comments are not auto-pick from another table using table transformer. I am comparing this as I was not able to find anything close to my requirement here.
Hi @MudCo ,
Please look into this Community thread (the answer from November 25, 2020).
There is an example how to merge Jira Issues table with a manually created table with comments using the 'Key' column. When published, these two tables will be displayed as a one whole table.
