The company I work for is considering implementing gamification, and I'd like to hear any feedback if you've implemented/integrated either Bunchball or Badgeville. It's also not beyond possibility that I may take the Badgr sourcecode and update it to work with Confluence and/or JIRA if the folks holding the purse strings have sticker shock.
Jim
Hi Jim,
I run Support and our customer community at Badgeville. We get requests for a Jira/Confluence connector frequently. We haven't delivered a packaged solution yet, I think, because technical teams use and support these systems and they can quickly integrate directly with our platform using both our REST API and JS library.
For example, you can embed an HTML macro in a Confluence page and then include our JS code to display visualizations.
Limitations apply if you are using Atlassian On Demand. For example, the useful links Rajat kindly provided above don't pertain to their On Demand solution.
Seems like this is for an internal project. Is that correct?
We've done some great work designing effective solutions for organizations like Deloitte that need consultants to share best practices internally and provide feedback on proposed solutions. Technology is just one part of the solution. I'd encourage you to make sure you have an effective strategy around design as well.
Send mail to paul at badgeville.com and I'll get the right team assigned to start your education.
Thanks Paul,
I'm sorry for not responding sooner -- I've been wearing a different hat for a while. This is for an internal project, but it's been put on the backburner for now. Thanks so much!
Hi Jim -
We haven't built a turnkey JIRA integration, but the question about JIRA integration did come up a few months ago. Our typical integration pattern requires:
From my quick scan of the JIRA docs, it looked like this would be straightforward - here are some of the relevant links I found:
Ping me if you'd like me to connect you or someone on your team with one of our local sales directors.
best, - rajat
rajat <-AT-> bunchball
Thanks Rajat,
I'm sorry for not responding sooner -- I've been wearing a different hat for a while. Looking into developing those kinds of plugins is a great idea. Thanks so much!
You can take a look at this project as well:
https://marketplace.atlassian.com/plugins/com.madgnome.jira.plugins.jirachievements
It looks like it has not been updated in awhile, but if you are looking at rolling your own, it could give you some ideas.
