We try to print a list of JIRA issues displayed on a Confluence page via a PDF.
This works fine, images attached to the JIRA issues are displayed on the Confluence page.
However when exported to PDF the JIRA issues do not contain the images anymore.
Is there a way to export/print the images from JIRA?
I am experiencing the same problem.
I am using the cloud version.
I created a report where I display some issues from Jira.
There are some images in the body of some issues.
They are displayed correctly in Confluence.
But the images are not displayed when I export to PDF or Word.
Since that is an old issue, I imagine that you should have a fix for that.
Flavio
I'm not sure if it is doable in your use case, but if you export the issues on the JIRA side with the PDF View Plugin, then you will be able to:
(You can select any combination of these options.)
Hey Willem-Jan,
hey Roya,
It's been quite some time to come up with an answer, but I just want to point you to the release notes of Confluence 5.6, especially the part on the improvements of the PDF export:
https://confluence.atlassian.com/display/DOC/Confluence+5.6+Release+Notes#Confluence5.6ReleaseNotes-PDFExportimprovements
This might be just what you're looking for - if it's not too late yet.
Philipp
I have the same question
