Is it possible to create JIRA issue from Confluence custom form ?
Jijo John [DevOps Consultant]
Hello team,
Can I create JIRA issue from Confluence page having custom form?
How can i achieve this using add-on or any hints that can configuring help.
Can i get confirmation back which JIRA issue id on confluence ?
Jijo
Rodrigo Girardi Adami
October 27, 2014
Hi Jijo,
As far as I know, from confluence 5.4 onwards it is possible to create JIRA issues from confluence side even having custom fields.
Check here: https://jira.atlassian.com/browse/CONF-23424
Rodrigo
Hi Rodrigo, Thanks, i already know there is an option to create issue from confluence. I see the issues with custom field using this, thanks for the link. Regards, - Jijo
